Re: How to remove a inner brake plate / bearing re
Posted by D Slater on September 25, 2006 at 08:54:32 from (152.163.100.65):
In Reply to: How to remove a inner brake plate / bearing retain posted by ENJ62 on September 25, 2006 at 07:47:57:
Plate is around 1/2 inch wide on outer edge,look for a parting line and some notches to get a pry started. Or screw a slide hammer in threaded hole in end of pinion shaft and they will both come out togeather. They are hard to get started out sometimes, When you get retainer out its no problem to remove seal. Retainer uses a O Ring to seal outside. If its a Super with disc brakes it comes out from outside.If its the bull pinion and differential carrier housing that needs removed the bull gear inside housing has to be moved out of way first.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
