Re: Super M control valve
Posted by Nat 2 on September 26, 2006 at 05:35:35 from (64.80.110.46):
In Reply to: Super M control valve posted by RoninKS on September 26, 2006 at 00:19:09:
1. Pressure out from belly pump to left side of valve.
2. Bottom of valve connected to fill tube on belly pump.
3. Two rear-facing ports run hoses to rear of tractor. End in hydraulic couplings, preferably quick-release so you don't rip the valve off the tractor, along with your leg, when the disc comes unhitched in the field.
4. Lock the belly pump lever back.
5. Lift and lower the disc by moving the christmas tree lever back and forth. If the lever seems "reversed" just swap the hoses.
