Re: Cheaper IH parts?.
Posted by Ted in NE on September 26, 2006 at 16:40:55 from (65.39.111.117):
In Reply to: Re: Cheaper IH parts?. posted by Jonfarmer on September 26, 2006 at 13:51:11:
Before spending the price for a new MCV, give the valve a through cleaning. Will have to remove it to do a proper job. Can polish the valves with crocus cloth. Have also lapped the bore the valves go in with very fine lappping compound like used for injector nozzles. Also make sure the pto valve is adjusted properly. Also check that pto linkage is not rusted up. Has to move freely so valve is in correct position or will cause problem you describe
Ted
