Re: Cheaper IH parts?.
Posted by Fromjb2 on September 26, 2006 at 16:49:03 from (69.198.143.165):
In Reply to: Re: Cheaper IH parts?. posted by Jonfarmer on September 26, 2006 at 13:51:11:
Hi Jon, I have forgotten what the original problem was? Was it the loss of pressure to the PTO clutch?
The MCV valve should be the same on 454,464,574,674,484,584,684,784,495,595,695.
There were two different hydraulic pumps, a 12.5 GPM on 684 and below and 784 and 884 had a 13 GPM pump.
The purpose of the MCV is to split the output of the 12 GPM pump and supply about 3 GPM to PTO and power steering and the remaining 9 GPM to the 3pt hitch and remotes. This is accomplished with a valve body with channels in it and valves with some springs and "O" rings and inlet/outlet ports.
If you have the mechanical know how a good shop service manual and an air compressor and some very fine emery cloth, for $1500 I would try overhauling the MCV. It is probably nothing more than a piece of dirt or broken "O" ring lodged in one of the ports or valves.
My 2 cents
JB2
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
