Re: 656 again. Houston we have a problem, and more
Posted by JT on September 28, 2006 at 10:30:46 from (70.226.196.117):
In Reply to: 656 again. Houston we have a problem, and more ??? posted by Harold Hubbard on September 28, 2006 at 09:50:13:
What you are descibing could be a hydraulic system that is not getting oil due to a restriction, as Allan commented, could have a hydraulic filter plugged on it.
No, the steering wheel should not spin free when off,
