Re: 656 again. Houston we have a problem, and more
Posted by Harold Hubbard on September 29, 2006 at 04:22:35 from (66.6.176.23):
In Reply to: Re: 656 again. Houston we have a problem, and more posted by JT on September 28, 2006 at 10:30:46:
Yeah, it sounds sort of like my 330 did when I first got it. I finally took the top off the hydraulic reservoir, cleaned out the half inch of gunk from the bottom, cleaned and reshaped the screen which had been collapsed, and the noise went away. I am quite sure the top had never been off since it came from the factory.
