Re: Farmall F-12 Leaks antifreeze
Posted by JayWalt on September 28, 2006 at 22:59:22 from (24.223.138.48):
In Reply to: Farmall F-12 Leaks antifreeze posted by Hank M. Willems on September 28, 2006 at 19:50:18:
I would definitely do some investigating to make sure it is not the crankcase. If it is the pump gasket or the pump housing itself, then you can probably talk the guy down some and fix it for not alot of money. If its the crankcase, I wouldnt even bother.
