Re: Idle Adjustment SA Solved.....
Posted by Andy Martin on September 29, 2006 at 05:30:32 from (64.219.39.195):
In Reply to: Idle Adjustment SA Solved..... posted by scotty on September 29, 2006 at 05:04:27:
The steering column should not be moving around. Is it bolted down solidly? Using bolts which are too long, or putting washers under the support column can lead to it being loose.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
