Idle Adjustment SA Solved.....
Posted by scotty on September 29, 2006 at 05:04:27 from (199.231.49.128):
I have done this procedure before with wide open throttle and adjusted the clevis going to carb.
The problem was the whole steering support column is moving around changing the idle characteristics of the motor !!! If I push foward on the steering column the idle goes down to where it should be ! My question is, is there supposed to be some sort of bracket from the electrical panel or steering post to the touch control to support that whole assembly from moving around. When I installed the steering support column I used big flat washers in the bottom of the electrical panel but I quess thats not enough. I am in the process of finishing the restore of this tractor and would appreciate any input !
scotty
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
