Re: Idle Adjustment SA Solved.....
Posted by City-Boy McCoy on September 29, 2006 at 09:58:48 from (70.149.233.192):
In Reply to: Idle Adjustment SA Solved..... posted by scotty on September 29, 2006 at 05:04:27:
The battery box is supposed to lend lateral support to the steering column on a Super A. It braces the column. mike
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
