Re: 22-36 year
Posted by RUSS HAMM on September 29, 2006 at 11:46:24 from (63.245.179.200):
In Reply to: Re: 22-36 year posted by Farm-all-the-way on September 29, 2006 at 11:06:50:
JOSH, YOU CAN SEE THE ONE TO THE LEFT IS THE BRAKE. THE ONE NEXT TO THE GAS TANK IS THE BELT PULLEY AND PTO LEVER. OTHER IS GEAR SHIFT. I MIGHT SUGGEST GETTING AN ORIGINAL OR REPRINT OWNER'S MANUAL. THIS IS INVALUABLE AS IT GIVES YOU THIS INFO PLUS VALVE ADJUSTMENT, TIMING, ETC.WE HAVE HAD SOME 6OR 8 OF THESE TRACTORS AND I SURE LIKE 'EM. KIND OF HEAVY, BUT. the original manifold came out the side, but you could get ih and heisler manifolds that came out the top later, some with zenith carb and some with the brass ensighn carb. i have noticed the zenith carb uses less gas than the brass one and you can jet and adjust it good. a friend of mine says the 22-36 numbers stood for 22 gallons of gas in the morning and 36 gallons in the afternoon. ha ha.russ
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
