Re: Need HELP-- C123 Engine --Carb
Posted by El Toro on October 05, 2006 at 10:48:33 from (64.12.116.65):
In Reply to: Need HELP-- C123 Engine --Carb posted by Jerry in WA on October 05, 2006 at 10:01:34:
Was the distributor removed from the engine? If it was the distributor may timed on the wrong cylinder. You may have fire, but at the wrong time.
If it was removed you need to bring No1 piston to TDC on the compression stroke, then look at the rotor to see where it's pointing. If it isn't pointing to the No1 plug tower, you need to pull the distributor and reset the rotor to the No1 plug tower and reinstall. Hal
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
