Re: No Start
Posted by El Toro on October 05, 2006 at 17:14:36 from (205.188.116.133):
In Reply to: No Start posted by Gary H1 on October 05, 2006 at 15:24:24:
Your distributor may not be timed to No1 piston.
You need to bring No1 piston to TDC on the compression stroke. Once the piston is at TDC pull the distributor cap and look to see where the
rotor is pointing. It should be at the No1 plug tower, if it isn't pull the distributor and then turn the rotor to the No1 plug tower. Then reinstall the distributor. It's very easy to time it on the wrong stroke. We have all done it.
Hal
