Re: 130 Oil Filter Leaking
Posted by Jossette on October 06, 2006 at 14:08:30 from (216.114.221.25):
In Reply to: Re: 130 Oil Filter Leaking posted by chad504 on October 06, 2006 at 04:43:34:
rubbing alcohol and a pipe cleaner works better( no distilate residue) you can put rtv in there but you have to go all the way around and then squeeze it out with the gasket-( going around it like you would with a piston ring). put a little oil on the gasket and lightly tighten the housing down, but not to tight--its just to get a level-square gasket. let it dry a couple hours and then tighten it to specs. no more gasket problems...
