Re: Framall 400 SM 264 cu engine
Posted by Dave in MN on October 08, 2006 at 05:47:45 from (204.221.132.71):
In Reply to: Framall 400 SM 264 cu engine posted by VOLfarmall on October 08, 2006 at 05:15:34:
As long as your TA works, you can be very competative in the 1st gear, slow speed classes. Lose the oil bath air cleaner, shave the stock head 75-100k, put a shorter, stiffer governor spring in, go to the electronic ignition with hot coil, use the 4 1/8 M&W pistons/sleeve upgrade (you don't have to bore block to use).
It will come down to how good a job you do balancing/weighting the tractor, type-tread-cut of tires and how good a job you do driving.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
