SM vs. SMD steering bolster
Posted by markloff on October 09, 2006 at 07:12:05 from (204.221.56.156):
Hello,
Why did the SMD use a 1.5 inch longer hood and front bolster. Was it to use a larger radiator, longer engine or both. Can you bolt up a SMD front bolster to the frame rails of a SM and then use the SMD hood? Can I then use my new SM radiator with a SMD bolster?
I ask because I'm in the process of putting a 2-71 Detroit Diesel in my SM and the exhaust is on the right and I'd like to use a SMD hood. I need to rebuild the front bolster anyways so if I can get a SMD front bolster so be it.
Thanks in advance,
Mark
