Re: SM vs. SMD steering bolster
Posted by D Slater on October 09, 2006 at 11:17:26 from (64.12.116.65):
In Reply to: SM vs. SMD steering bolster posted by markloff on October 09, 2006 at 07:12:05:
Yes a MD SMD and after that, SMTA,400 or 450 gas or diesel will bolt to your frame rails and radiator and longer hood will work. Think longer engine is why MD and SMD used bolster that extended farther forward. Whan they got to SMTA up to 450 they made Diesel length standard for both it and gas. Later bolster used squared off corners with holes though. Start crank parts are different on some, but that won't matter with your engine change. Also bolsters I'm refering to are for regular farmall row crop tractors, not V series. If your going to use a standard steering worm shaft, get the diesel one with bolster.
