Re: International 806
Posted by john IH on October 09, 2006 at 15:49:44 from (205.188.116.133):
In Reply to: International 806 posted by Luke Baker on October 09, 2006 at 14:35:06:
check your hydraulic oil filter, possibly replace with a new one(right side of trans). or the pump posibly needs replaced. pump is on back side of the ta control valve plate (left side below battery).hope this helps.
