Re: road gear on H is shot
Posted by Josh in Pa on October 11, 2006 at 12:13:04 from (130.203.208.156):
In Reply to: Re: road gear on H is shot posted by Dakotaclassiccycle on October 11, 2006 at 11:57:31:
Its not hard, but its gonna take some time. You have to remove the cover over the transmission and final drive. (The big cast iron one that the steering column and seat attach to). You have to remove the hydraulic pump, and remove the coupling between the clutch and the input shaft of the transmission. The you can remove the transmission input shaft through the belly of the tractor. After this, the 4th/5th slider gear can be slid off the shaft. I also moved the detent in my shifting rail a little bit (1/16") so that it would really go into 5th gear. Its not hard, but your in for a bit of a job.
Josh
