Re: Opinions Needed?
Posted by JT on October 11, 2006 at 16:14:25 from (70.226.225.106):
In Reply to: Opinions Needed? posted by kfox on October 11, 2006 at 15:57:47:
As Hal pointed to, valve springs come to mind, is the timing OK on it, have you set it correctly? You might check the float level on the carb, if it starts with no choke, you are overfueling somewhere, you should have to use the choke a little at first when starting cold. And if the float was set too high, that would also explain the excessive fuel being used. Did the valve guides get finish reamed when they were put in, it also sounds like you could have some sticky exhasut valves. You said it has new guides and seat, did the valves get ground and lapped, they might not be seating correctly.
