Re: Opinions Needed?
Posted by CNKS on October 11, 2006 at 17:35:06 from (204.249.178.135):
In Reply to: Opinions Needed? posted by kfox on October 11, 2006 at 15:57:47:
My Super H had a random "miss". I had originally set the timing with #1 at TDC "by the book". I then set the timing by rotating the dist in and out until I got the max rpm at idle. The miss went away. Occasionally the answer is simple. I don't know what you mean by using too much fuel -- in comparison to what it used before the overhaul? About all you can do is lean the carb to the point that it begins to miss, then open it until smooth plus maybe 1/4 additional turn. This assumes that the valves are set to spec.
