Re: Broken Seat Spring.. Fact or Fiction?
Posted by markloff on October 12, 2006 at 11:24:25 from (204.221.56.156):
In Reply to: Broken Seat Spring.. Fact or Fiction? posted by 772TAS on October 11, 2006 at 20:11:24:
Hello,
Did anybody know this is the reason the old Regulars and F-20, 30s had two bars in the old leaf spring seat? If one broke the other would hold you on the tractor.
Mark
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
