Re: C 113
Posted by El Toro on October 12, 2006 at 14:35:36 from (205.188.116.133):
In Reply to: Re: C 113 posted by teddy52food on October 12, 2006 at 06:26:13:
Rotate the engine 180 degrees and then look at the flywheel timing mark and your No1 piston should be at TDC. Another way to tell if you are on the compression stroke with No1 piston is to
check both valves on No1 cylinder. Both valves should be closed. Then this where you would install your mag or distributor with the rotor pointing to the No1 plug tower. Hal
PS: Once you have the head on and the valves adjusted put your thumb over No1 plug hole and have someone hand crank the engine until you feel compression and then look for the timing mark on the flywheel until it is aligned.
