Re: 52 cub-carb float
Posted by Gary Beal on October 14, 2006 at 19:46:54 from (66.72.58.45):
In Reply to: 52 cub-carb float posted by RP-40-9n on October 14, 2006 at 19:32:26:
Hold the carb up level with the float bowl off, attach a small piece of hose to the fuel inlet, blow gently on the hose as you push up on the float. This should give you a good idea where the float is when the fuel actually shuts off. Adjust the float so it is level when the fuel is off.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
