Re: pedal adjustment on an h
Posted by tn terry t on October 14, 2006 at 20:47:29 from (64.12.116.65):
In Reply to: Re: pedal adjustment on an h posted by voager213 on October 14, 2006 at 20:14:37:
the only adjustment is located on the arm that comes out of the brake cover its a spring looking out fit with the threaded rod going to a nut made onto the springy thing boy how did you like that techincal description
