Re: pedal adjustment on an h
Posted by kfox on October 15, 2006 at 07:10:19 from (63.18.240.52):
In Reply to: Re: pedal adjustment on an h posted by voager213 on October 15, 2006 at 07:02:03:
Loosen the jam nut on the threaded end and turn the clevis. (with the pin removed) :-)
If its old & rusty looking, it's best to remove the whole thing and free it up on the workbench. I have two adjusters off of a H that have the clevis broken off the threaded shaft. They are just stuck on with a kind of spot weld. The adjusters are rare in the boneyards around here, so it must be a fairly common problem. ken
