Re: Lubricating Throw Out Bearing
Posted by Steven@AZ on October 15, 2006 at 08:59:49 from (24.121.155.253):
In Reply to: Lubricating Throw Out Bearing posted by JayWalt on October 15, 2006 at 07:49:17:
Lubricating the throwout bearing is a good idea, but it is most likely not your problem. If the throwout bearing was bad, you would hear a noise when you push the clutch in.
I think you may have an adjustment problem. Do you have a TA? If so you need to follow the adjustment procedure EXACTLY or you will have problems.
If an adjustment doesn't help, then you may have trouble with the pilot bearing.
