Re: trailer wiring
Posted by KEB on October 15, 2006 at 11:34:40 from (72.19.170.5):
In Reply to: trailer wiring posted by scotc on October 15, 2006 at 11:12:00:
What kind of stranded wire are you using from Home Depot? If its the typical house type stranded with maybe 10 or 12 strands it'll work harden wherever it flexes and eventually break. Particularly a problem where it flexes when the axels move up & down & where it goes into the tow vehicle connector.
If you look at automative wiring, even the e-cheapo stuff Wally World carries, you'll notice its made up of a large number of fine strands. This is to help keep it from breaking where it flexes. Cables made up to flex, like welding cable, have even finer strands. I've used outdoor extension cords as a source of multi-conductor wiring for trailers, works well, flexes easily, is readily available, and cheaper than automotive wire.
Keith
