Re: h w/disc brakes
Posted by Haas on October 16, 2006 at 18:59:55 from (12.65.36.103):
In Reply to: Re: h w/disc brakes posted by bbaro36 on October 16, 2006 at 14:48:04:
If you take the actuator apart, assemble that on the bench. Best to take the actuator apart and check the balls and ball tracks to make sure they are clean with no pits, corrosion. Smooth ramps and balls are essential for these brakes to work good. after the actuator is all together, assemble the disk, actuator and second disk onto the splined shaft. Then put on the cover and hook up and adjust the linkages. Check the splines to make sure they are smooth and the disks move freely on them. I hope all this is correct. It's been 5 years since I did it and this is what I recall.
