overheating on a 400
Posted by jaybone on October 17, 2006 at 17:19:04 from (64.12.116.65):
Sequence of events--boilover out of the cap and overflow pipe. Flushed radiator with cleaner then new antifreeze/water at 50/50. Straight water flushed right thru (so radiator not plugged,right?). Ran motor-same thing. Got block tester from local mechanic-no apparent gas in radiator fluid. Also, no antifreeze/water in oil pan or dipstick. So, head gasket ok--right? Level of fluid in radiator at spec level so not overfull and just running over.Hoses ok.Blew out the radiator fins with water and comprssed air--some junk out but seems open to airflow. Any ideas of what to check next? Really puzzled.Thanks
