Re: 340 power steering line leak
Posted by Janicholson on October 18, 2006 at 20:14:06 from (66.173.50.20):
In Reply to: 340 power steering line leak posted by old on October 18, 2006 at 18:43:34:
Old,
Brazing will work Braze a steel patch over it if it is a hole. cover the sides 1/4" or so. If it is a crack near the fitting/block, I would braze weld (meaning build up some thickness to the bronze) to help it stop cracking. Don't over heat the bronz, the zink will vaporize out of it and it will be no where near as strong. If white smoke and bright firelooking things are happening it is too hot. From my experience. Good evening to you, JimN
