Re: M starting problems
Posted by John T on October 19, 2006 at 08:45:41 from (66.244.90.5):
In Reply to: M starting problems posted by Granger on October 19, 2006 at 07:59:51:
Granger, yours is a wide open question and sounds mostly starter performance related, but may involve some ignition or other problems, but I will just address slow or weak cranking..... The FIRST thing I would suspect is the battery, insure theres electrolyte above all the plates and that no cells exhibit a gray or milky color indicative of a weak cell and next give it a good slow full charge and better yet have a shop LOAD TEST it or try a know good substitute battery n see what happens??????????? Next, if none of that helps much I would remove, clean n wire brush shiny, n reattach each n every battery n starter n starter switch n ground cable conenction n see if that helps. If the ground cable is attached to any thin or rusty sheet metal, maybe try it to a clean solid bolt somewhere????????? If still shes a slow cranker with a good battery n all good cables n connections, I would try to by pass the starter switch by using jumper cables to jump around/across it or just jump the hot ungrounded battery post direct to the starter n see if she cranks better then????? If by pass jumping around the starter switch improves cranking, I would suspect the switch. Turn the lights on when cranking and if they dim wayyyyyyyy down badly and/or the voltage drops drastically, I suspect the starter motor itself, but if theres not much change in voltage or light brightness, then I suspect the starter switch more. FINALLY if the battery,,,,,,,,all cables n connections n grounds,,,,,,,,the starter switch are allllllllll okay but she cranks weak n slow, then I suspect the starter is at fault, maybe it just needs new brushes or the armature is dragging or otehr problems. Sounds like it may simply be a cable or bad connection problem, so try that and check the battery condition first. Let us know, best wishes n God Bless John T
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
