Re: Super A mystery
Posted by Pa. Pete on October 19, 2006 at 11:25:40 from (207.7.183.166):
In Reply to: Re: Super A mystery posted by Hugh MacKay on October 19, 2006 at 10:20:21:
third party image
Thanks for the replies, guys. This forum is awesome.
Hugh, the inner diameter is 1 3/8 inches, but I can't 'see' the axle to measure it.
I took the pan to some local guys and got it welded, after beating it back into shape. LOL, they told me that washer BELONGS in the pan, it keeps the oil stirred up! Comedians! LOL
I took off the inner axle cover, and I believe I see the washer hard up against the bearing. Guy must have just replaced it when he "lost" the original. I guess I'M lucky it finally jammed when I wasn't mowing, when I wouldn't have noticed it in quite a while. How he didn't know where he dropped it is beyond me. You'd have to know it would cause havoc sooner or later, landing in the pan. A magnet could have retrieved it pretty easy.
Can I ask the next question to which this leads? That bolt must screw INTO the axle. When I put a wrench on it, it wasn't loose, but it wasn't tight, so I wondered if it was used to take up the bearing tolerance, but then there's nothing to hold it from loosening, and I would have sooner expected a castellated nut and a cotter pin. Do I have this wrong? Do you use that lug-ed spacer to set the tolerance, and then turn this bolt down tight?
Oddly, my parts-manual doesn't show this bolt at all, nor one of these washers on the other side. Makes it hard to tell what's supposed to be where.
Again, my appreciation.
