706 wont start. Getting mad now!
Posted by Kelly C on October 19, 2006 at 15:33:28 from (65.165.20.97):
Ok here is the deal.
706 Gas. I get spark. It gets gas and it drips out the bottom of the carb sort of like it is flooded. Plugs are way dry though. I give it a shot of ether and she fires. but wont run past the ether.
That little cylinoid thing clicks as it should when turning the key.
Whats going on here???? Why wont it run?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
