super m charging
Posted by scotc on October 19, 2006 at 16:35:12 from (204.110.228.135):
A couple years ago I dropped a 12v battery and ballast resistor with new cables on the sm, and it's been charging ever since and I've never had a voltage regulator last as long as this one. Since I finally figured out the bad gas problem, I've been starting it up for a few minutes every week. Last month I hotwired my headlights that I never did get wired properly, and I've noticed that when I turn them on, My ampeter actually reads HIGHER. I've never seen that before, it always read lower before I went to 12v. I'm also getting my power off the cable at the solenoid instead of in the box with the ampmeter, ignition switch, and rotary light switch. Is this something odd or should it do that?
