Re: 574 Clutch Progress
Posted by FromJB2 on October 19, 2006 at 18:29:01 from (24.150.238.188):
In Reply to: 574 Clutch Progress posted by BEWILDERED on October 19, 2006 at 18:09:47:
Hi Bewildered, good news that you can fix the clutch problem. Clutch return spring is very important, they often break and fall off without notice.
I think someone has already mentioned to mount pressure plate and clutch on the shafts, then put tractor back together then put bolts in pressure plate/flywheel thru inspection hole. Some people take the starter out so they can use a screw driver into the ring gear to turn engine over to get next set of bolts in flywheel.
Good luck
JB2
