Re: Farmall Regular Crankshaft Pulley and Flywheel
Posted by Tom Windsor on October 20, 2006 at 00:06:20 from (152.163.100.65):
In Reply to: Re: Farmall Regular Crankshaft Pulley and Flywheel posted by Tom Windsor on October 19, 2006 at 23:56:39:
I failed to mention...the reason for the caution...I bought the nut that holds the flywheel on a JD-B last month...Just a little old thing...$16.75
