Re: Voltage/Current drain...
Posted by Janicholson on October 20, 2006 at 06:12:35 from (199.17.6.122):
In Reply to: Re: Voltage/Current drain... posted by hhmm? on October 19, 2006 at 21:21:02:
Sorry, the post was in reference to the earlier dialog and analysis procedure. I had indicated that if one battery post (in this case the pos) was disconnected, and a volt meter was placed between the removed terminal, and the bat post, that there would be a 12+ volt reading on the meter with everything shut off if there was a battery drain. The disconnection of the alternator (which I believe is faulty) would result in that indicated 12+volts to go to at or near zero. Give the other post a look see and I think it will be understandable. Sorry for an incomplete post out of context. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
