Re: Super M Ignition: Won't run same way twice?
Posted by Bob M on October 23, 2006 at 09:47:08 from (151.190.254.108):
In Reply to: Super M Ignition: Won't run same way twice? posted by Dennis Gauge on October 23, 2006 at 09:15:40:
Dennis – You might be on the right track thinking it might be a cam/valve timing issue! Depending on how it is used the live pump on the Super M puts a very heavy load on the cam drive gear. Cam gear retaining nuts can loosen, or even unscrew completely and fall off. This causes either woodruff key in the gear hub to shear or the gear hub to break. After this happens the tractor may still run, but will run erratically and poorly. Also it may run differently upon each startup since the crank rocking backward each time it stops repositions the cam drive gear relative to the camshaft and hence changes the valve/ignition timing. The fact the engine won’t start now indicates the camshaft is too far out of time for the engine to run at all. ---- A couple things to try: 1 - Remove the rocker box. Turn the crank by hand until the TDC (single notch) timing mark on the crank pulley is aligned with the pointer. Now check the valves on #1 and #4 cylinders. Both push rods on one of the cylinders should be free - doesn’t matter which cylinder - indicating the valves are closed. If not it means the camshaft is out of time. 2 - Mark the position of the distributor rotor then pull the distributor/live pump assembly from the engine. The cam drive gear is visible just inside timing cover. Use your finger or a screwdriver on the cam gear and see it can be moved around. If it moves at all it’s either loose on the camshaft or the gear hub has broken.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
