Re: farmall serial numbers
Posted by CNKS on October 24, 2006 at 20:22:34 from (204.249.178.135):
In Reply to: Re: farmall serial numbers posted by glennster on October 24, 2006 at 15:07:53:
Strange things do happen. My Dad's 47 H, bought new had the kero/distillate carb, at that time I did not know the difference (1950 through about 1960), and I don't remember the manifold. I am positive it did not have the starting tank. But, the tractor was bought new in Jan 1947, I did not start driving it until I was 12 years old in 1950,so my memory of what it was like when it was delivered is non-exsitant. The carb could have been replaced with a distillate/kerosene one, for whatever reason. I believe that the kero/dist tractors usually did not have a suffix, no proof of that. As to the 49 H, unless you are positive about its history, the hood, manifold and carb could have been changed. I have a junky 1941 dist/kero H that needs a new carb (one of the attaching bolt holes is cracked, the hood is about beyond repair, the manifold may or may not be ok. Along with a hundred other things. If I fix it up, I may put a gas carb, manifold, and hood on it simply because I like them better. To be legal, since it needs an engine overhaul, I will definitely put new pistons in it and could change the head for not much additional expense. At that point I could put an X1 serial on it, because it then really would be an X1 tractor, it just didn't come from the factory that way. So you can take this and what I wrote below for what its worth, which may be nothing.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
