Ignition System Problems
Posted by Larry Schmitendorf on October 24, 2006 at 20:33:34 from (24.124.102.200):
I have a 240 Utility, wehnt o use it and it wouldn't start. A new coil got it running for about 15 minutes. A little investigation found a bad resistor. Now 2 resistors, another coil, points and condenser and it still won't start unless I bypass the resistor. Then it starts and runs fine. I tested the ignition circit with the distributor cap off, ignition switch on and I get votage to the points through the resistor, and coil when I hold the points open. However when I try to start the enginge I loose spark. I'm thinking a bad ignition switch. Any other ideas?
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
