Re: Question on tractor A? C?
Posted by CNKS on October 27, 2006 at 11:51:05 from (204.249.178.135):
In Reply to: Question on tractor A? C? posted by magman on October 27, 2006 at 10:27:33:
The prefix you listed is FAAM, not RAAM. That is a Super A engine prefix, the Super A and C engines are identical, except the governed speeds are slightly different. The engine prefix for a C/Super C is FCM. Since you have drum brakes, you have a C, not a Super C. The chassis serial is supposed to be on the right side of the tool box, it is missing or you would have seen it. If I missed something, someone will tell me about it. Casting codes are usually different, as they were cast over a period of days to months.
