Re: Question on tractor A? C?
Posted by Randy in NE on October 27, 2006 at 15:01:09 from (204.124.192.31):
In Reply to: Question on tractor A? C? posted by magman on October 27, 2006 at 10:27:33:
The serial number is too high for a Super C. I954 started with 187788. Not sure if the motor was replaced with a motor out of something else. Like Nat2 said, the tool box has an opening on the back. A C will have band brakes. Also the gas tank sits right on top of the touch control unit on the C and have about 2 inch gap on the Super C. Paul Shuler has a nice picture of his C and Super C setting side-by-side. The C will have 36" tires on it and you sit right in the middle of the tractor. The steering wheel is slightly off-center to the left since the steering shaft runs down the left side of the tractor. I am leaving for the weekend but you can call me and I can e-mail you some pictures of my C and Super C. Randy (402)981-6633. Otherwise send me an e-mail and I will send them on Monday. My e-mail is uncovered.
