Re: Zenith Carb drip
Posted by K-Mo on October 29, 2006 at 15:20:47 from (65.169.189.2):
In Reply to: Zenith Carb drip posted by SuperA-Tx on October 29, 2006 at 15:02:55:
Don't JB Weld the hole. That's where excess fuel is supposed to drain out. What you called a kind of white plug is probably a small welch plug which is retaining a small felt filter. The filter keeps dirt out and lets excess fuel drain out. You need to resolve the problem of the source of the excess fuel. Maybe your float valve is leaking or your float level is too high.
K-Mo
