Re: Super A pulley/pto rpm, also V-belt drive?
Posted by Hugh MacKay on October 29, 2006 at 17:33:39 from (209.226.106.158):
In Reply to: Super A pulley/pto rpm, also V-belt drive? posted by tractorsam on October 29, 2006 at 15:04:33:
Sam: If you go to any bearing, pulley, etc. shop they can supply you with a taper sheive pulley for either pto or the pulley shaft. I had one of these mounted on pulley shaft before I switched my 130 to 12 volt. I had the alternator and battery mounted on platform directly under seat. I used this many years for operation 12 motors on an attachment I had for tractor.
