Re: IH 756 Engine Help Needed
Posted by Sean Wetgen on October 30, 2006 at 11:02:28 from (204.77.166.193):
In Reply to: IH 756 Engine Help Needed posted by BWNOK on October 30, 2006 at 10:50:22:
If it were a head gasket you would have a hint of whiteish smoke. After it setting that long did you drain the antifreeze and replace it? Have the radiator off? Sounds like maybe part of the cooling system is plugged. That it builds the pressure so fast even cold, it has to excape somehow. And a radiator cap is usually only made up for 10-14lbs of pressure. If he was having problems with head gaskets, maybe at one point he used stop-leak or something to help it. And if stop-leak sets for a long period of time without any circulation it'll settle and plug things up. Check the simple stuff first then move on to the major.
