Re: Power Steering went out omn my 1066?
Posted by agrogers on November 01, 2006 at 14:22:06 from (72.10.243.156):
In Reply to: Power Steering went out omn my 1066? posted by dej(JED) on November 01, 2006 at 05:11:13:
Had the same thing.
Blown O-ring in one of the pressure ports of the MCV. Took
longer to drain the oil, pull the valve apart, hee and haw about
what it might be than it did to actually pop in a new o-ring and
put it all back together.
Could be other stuff too, just my experience.
