Re: 1944 M Stuck in 4th gear
Posted by gene bender on November 02, 2006 at 03:43:28 from (67.55.226.214):
In Reply to: 1944 M Stuck in 4th gear posted by tim tonjes on November 01, 2006 at 22:42:22:
You are stuck in two gears. Drive pin out of shift lever and remove the shifter. Then look in the hole and you will see the rails. Using a large screwdriver you can line the one that is not lined up with the other two. Mite have to tie the clutch pedal down to remove any binding and if tractor is not on the level block the wheels so it cant roll away. You need the shifting lever built up a little to avoid this again. Dont get upset as this has happened thousands of times over the years.
