Re: 1944 M Stuck in 4th gear
Posted by Nat 2 on November 02, 2006 at 05:33:19 from (64.80.108.53):
In Reply to: 1944 M Stuck in 4th gear posted by tim tonjes on November 01, 2006 at 22:42:22:
What gene said.
The starter problem is a completely separate issue that just happened to coincide with the tractor getting stuck in gear. The starter will need to be removed, and the drive ("Bendix drive") serviced or replaced entirely. It's probably a broken spring, but I would wager that the gear is pretty worn as well.
