Re: I foudn a tractor with my wheels on it.
Posted by El Toro on November 02, 2006 at 10:21:27 from (205.188.116.133):
In Reply to: I foudn a tractor with my wheels on it. posted by Mike CA on October 30, 2006 at 00:04:01:
third party image
Hi Mike, You mentioned in one of your early posting's that you didn't have a workbench. Here's a plan that I found that looks similar to my work bench I made 40 years ago. I used heavier
lumber than the bench shown. I took the dimensions from my bench. I have 2 vices and a
grinder bolted to the bench, very handy when you need them. This is the lumber list that I used. Hal
A. 4X4X36" legs 36"long 4ea.
B. 2X6X331/4" 2ea.
C. 2X6X721/4" 2ea.
D. 2X4X691/4" 2ea. Note: I installed a shelf 15" above the floor using these 2x4's nailed to inside of the 4X4 legs. Used 1/2 plywood for the shelf. Cut to size
E. I didn't use E on my bench.
F. Top 3/4" plywood 36"wX721/4" long.
Assembly: a. Nail (B) across the 2 (A)'s flush w/top. Do the same w/the other (B) and (A)'s.
b. Nail (C) to (A) front and back.
c. Install (D) inside the legs (A) lengthwise
15" above the floor. It's handy for storing.
d. Install 3/4" plywood on top. I only used
small galvanized nails on the top since it will become worn with use. Then I removed it and flipped it over with the unused side up.
You can get new wood scraps at Home Depot. I would buy good lumber. I think my legs are maple,
but you could use fir or something similar. I have even set engines on my bench.
